3 volts will it run a white 5 mm led?
raggie33
*the raggedier*
i wanna put one in my maglight just wire it straight will that work?
vcal
San Gabriel Valley
It depends on the individual LED. Some will, some won't, -but none will be very bright.
-Get some 2/3 AA Nicads -3 of 'em will fit in your 2-AA minimag. They will give you a voltage total of 3.6-3.8 and run any white LED very brightly. /ubbthreads/images/graemlins/thumbsup.gif
IlluminatingBikr
Raggie33,
I made my own 2xAA light driving two 5mm LEDs in parallel. Yes, it will work (either direct drive or with some resitance) but isn't very bright.
I would recommend you take vcal's suggestion about the 2/3AA cells to get some better voltage to your LED thus making it brighter.
EDIT: Make sure you get the polairty correct. /ubbthreads/images/graemlins/smile.gif
IlluminatingBikr
Raggie, you have an interesting idea, and I decided to do it just now.
I pulled the incandescent bulb out of my Minimag just enough to be able to touch the leads of my DMM to them and check the polarity. After I had established which side is positive and negative, I took out the bulb and held in a 5mm. I had to hold it a certain way to get it to light up. When it did light up, it wasn't very bright at all. The incandescent bulb was many times brighter. Even though it is a 5mm LED, it wasn't as bright as a 5mm driven even at specs. It was dimmer than the an Arc AAA or CMG Ultra-G.
So it works, but isn't very bright at all.
Stanley
Canberra, Australia
Raggie, if you haven't seen it already, here's a link to Quickbeam's site, which has a huge list of mods, ranging from simple and cheap to complicated stuff, which have been contributed by various knowledgable CPFers... Think there's enough stuff there to keep anyone busy for a while!! /ubbthreads/images/graemlins/wink.gif
wwglen
NC
Use Lithium 1.7 volt batteries direct drive and it is about as bright as my Ultra-G.
wwglen.
The_LED_Museum
*Retired*
Federal Way WA. USA
One version of the Electralumes fishing light uses two white LEDs and two 1.7 volt lithium AA cells. The LEDs are bright, but not overly so.
Somewhere on my website, I have a page about these...ahhh, there it is if you wish to see it.
