I have never done a review and this won't be one.
That said I was fortunate enough to be given the chance to use and play with a pre-production unit thanks to the folks at 4Sevens (it must be returned after 3 weeks....more on this later).
What follows are my purely subjective and unscientific observations.
The packaging is the same as the SR50.
They supplied the 18650 carrier for testing but all else in the photo is included(not the CR123's).
Size comparison, M40A, SR51, 2D Mag.
The business end.
This unit had a unique "feature" I noticed after turning it off in the dark there appears to be glow powder in the o-ring as seen in the photo, not sure if it is intended or not, needless to say IMHO it has no adverse effect.
I can't get good long distance beam shots so what you get are a video comparing it to a 3D Mag with an XM-L drop in rated/measured at 880 lumens, and my "Umbrella Bounce" shots.
http://www.youtube.com/watch?v=OvINmyFAxpQ
The video shows the 3D mag/XM-L drop in first, then the SR51, then the SR51 above the Mag/XM-L drop in
M40A
3D Mag with XM-L Drop in rated at 880 lumens.
SR51
Thoughts:
I must be up front about my want for a medium sized side switching light, the SR51 fills that want/need very well.
The build quality is very good although I would like to see the body a tad thicker at the sides.
The battery carriers are very nice, the 18650 fits button and non button topped 2900 Mah fatties with ease.
The UI is straight forward and the new "lockout" feature a great addition.
The Diffuser works nicely.
Output, well it "punches" light out to 300 yards easily, the claim of 700 meters can neither be confirmed or denied by me.
Beam quality is excellent, and a warning to white wall hunters, this thing is crazy bright at close range.
Runtime/heat, I only ran it on 18650/2900 cells and got 103 minutes until complete shutdown so I never burnt 6 CR123 with results like that(because I saw no difference in ouput between 2/18650 and 6/CR123). It got quite warm but never too warm to handle.
Parasitic Drain, I have had it sitting for nearly a week and I see no evidence of high parasitic drain.
Bottom line:
I had one on pre order and I am glad I did ( it might be here tomorrow) in fact I have been begging the "Chairman" to let me purchase this unit(at full MSRP) but to no avail.
If my production version is as good I will be buying at least one more.
That being said I would gladly forgo the nice case for a ballistic holster and a heftier body but as it stands it is still worth every penny at this price point.
The business end.
M40A
SR51
Thoughts:
Bottom line:
