I have been vacillating between the clear lens with DC fix and the frosted lens with my ST5-190NW. I've currently got the frosted lens in it, and think I'm going to be staying with it.
I find it does reduce the output somewhat, but I can live with that. Even with the frosted lens, it's brighter than my H51w on L2, which is too bright for 'moonlight' mode use. I think the beam is still a 'directional flood' but more so than with the DC-fix. There isn't any real hot spot in it at all, but it is brightest in the center, gradually dimming as you move toward the edge of the beam.
One thing I have noticed, is that the spread of the Spark is wider than my ZL; it literally fills my entire field of view when I have it on. I also find the extra strap makes it more secure, and so it's better for more active uses than my ZL. Because of the narrower beam of my ZL, and since I got the Spark, I find I tend to use the Spark more for outdoors kinds of things, and the ZL for indoors things.
