What P60 host are you using that can take 4 AA cells?
x3 18650 Leef body w/ AA sleeves.
ash11,
I'm sure you'd get the 100 lumens for 10 straight hours with eneloops.
You can use any battery chemistry as long as voltage doesn't exceed 9V.
Eneloops are worth the money if you take care of them, which is easy with a good charger and common sense(find info in the battery section).
Another suggestion to use your Leef x3 18650 body is:
x2 18650 and x2 CR123 Dummy Cells-- that'll give you insane runtime.(20+hrs??).
ALSO, instead of the x2 CR123 Dummy Cells, you can contact MartinDWhite for a "Dummy 18650 Cell".
