Ian2381
I'm looking for the brightest 4xAA flashlight that can somehow match the power of Fenix TK41. Is this possible? I'm leaning towards AA powered lights only, already got 18650 XML lights.
Isn't it possible for a 4xAA light to reach the max output of TK41 even on half the runtime?
I'd imagine that it's possible, but apparently no manufacturer builds a 4AA model that can do that. If such a 4AA model was built, its current draw would be quite high for AA cells so runtime would be very short even using lithium AAs.
The brightest production 4AA isn't even half as bright as the TK41.
Hopefully someone will create such a light, even on less than an hour on max mode will be enough for multi mode lights.
output in lumens is nearly useless for specifying throw.
Not a 4AA but 3AA & 2AA
Any high powered LED must be aluminum construction to dissipate heat quickly to save LED module.
Another choice is XML 4AA 1D M*g
Please note that original poster never used the word "throw", so why using lux or cd? He did mention brightness, power and max output, though.
True, plastics and carbon fiber composites in particular are notorious for their poor heat conductivity. Still, there is enough surface for heat transfer on the head IMO. I wonder whether "carbon fiber reinforced composite" refers to a moulded thermoplastic (PA-GF alike), often found on power drills...When i asked WHY?! isn't aluminum good enough anymore, they told me it's because aluminum is heavier than plastic! I would have also accepted the fact that Carbon Fiber Reinforced Composite is far more tactical sounding than Aluminum.
Because the OP asked for the BRIGHTEST 4AA flashlight, and BRIGHTNESS is specified in units of LUX or CD.
Brightness refers to Peak Beam Intensity, which is a good predictor of Throw.
Throw refers to the maximum distance at which the Peak Beam Intensisty remains sufficient for useful illumination of a target.
A flashlight's output specified in Lumens or Watts specifies absolutely nothing about its Brightness (Peak Beam Intensity) or its Throw.
Not exactly, I reckon the brute force of my TK35 will kill nearly all of your current "throwers"
Maybe it does, maybe it doesn't.
You could prove it one way or the other by specifying the Peak Beam Intensity of your TK35.
Your reckoning that brute force will prevail over Peak Beam Intensity runs contrary to some very basic physics.
