think2x
I haven't seen much on here about any of Streamlights products and let curiosity get the better of me. I haven't have them long but thought I would give my "first impressions" here. I don't claim to be a wordsmith or a photographer so please forgive the crudeness of this "review" if you will.
First up is the Night Com LED.
It's almost identical in length to my C2 with crenelated bezel. The Night Com has a tail switch AND a 4 position dial at the head. Going clockwise starting at the 12 o'clock it goes SAFETY(lockout), NV LED(ultra low red), HI LED(red), LIGHT(cree XR-E)
NOTE: I did sand the two ultra bright red leds because the beam was horrible with artifacts, this seemed to clear it up totally.
The Specs
C4® LED TECHNOLOGY / NIGHT VISION PRESERVATION FLASHLIGHT
C4® LED technology, 2-3X brighter than High Flux LED
C4 LED: 4,500 candela peak beam intensity; 105 lumens
Runs up to 3.5 hrs
(2) Ultra-Bright Red LEDs: 2.5 lumens; Runs up to 28 hrs; for use when true night vision preservation is NOT necessary
Indicator Type LED: Preserves complete dark adaptation per MIL-1472D (<0.05 lumens); for use when true night vision preservation IS necessary
Dual Switch System features an engineered tailcap switch for Power On/Power Off and signal
Tailcap switch: On/Off and Signal Mode Select Sequence; (2) Ultra-Bright LEDs /(1) Indicator-type LED / C4 LED / Safe
Powered two 3V CR123A lithium batteries
Corrosion-resistant anodized aircraft aluminum construction
Limited lifetime warranty
Camera on manual settings.
Light Set on NV LED <0.05 lumens. One 5mm red indicator LED. This is a true ultra low red that makes the 0.07 of my RA Clicky look bright.
Light set on HI LED. Two ultra bright red 5mm LEDS 2.5 lumens, looks brighter too me but I'm no expert.
Light set to the main beam. Cree XR-E 105 lumens. This beam is focused for throw. I went out last night while there was a mist in the air and the beams angle is pretty much on par with the Malkoff M60, though obviously not as bright. I was surprised how far this thing reached compared to some of my others. The tint of the XR-E is the PUREST of white to my eye and I tend to be picky.
Over-all my only real complaint with this light so far is the lens is pressed/glued in.
I bought the Night Com because my wife asked me for a light for her car. The safety lockout and sub $40 price is what sold me on this one.
The Specs
Runs up to 3.5 hrs
