MartinDWhite
I have two H60 headlights, one Warm and one cool. With a correct sized spacer (I made the spacer) one of them has been run for about 5 minutes on a CR123A. Are there any issues with this?
zebralight states that those models are 18650 li-ion only...
which is why ive never picked them up... i dont know what will happen with 2x primaries... maybe others have tested it?
You should check the marketplace. Someone there makes and sells 18650 sized spacers that you can use with AA's. They might have them available for 16340's as well. That way you could run the light on a single RCR123 and it would perform just like an 18650 except for the run time.
I am the one that makes the spacers. They are available in anysize, since I custom make them all in my garage.
