Shooter21
how do they compare in terms of throw? thanks in advance
I take it that the DEFT is slightly brighter in the centre by a nose??? By a small amount that is.
Because the XR-E may have a slightly higher surface brightness than the Luminus SST-90 depending on whether it is the 1mmx1mm die model, or the 0.9mmx0.9mm die model.
The SR-90 has a huge hotspot and a vast lateral spill...
HKJ, do you have a similar beam shot at the same location for either a: RRT-3, M2S, Et M3C4 XM-L, Thrunite Catapult V3 XM-L, or Olight M3X XM-L, for comparison purposes, because the SR-90 is impractical to lug around?
