luceat lux vestra
finally the new 4Sevens Maelstrom X10 is here!
The Maelstrom X10 utilizes the ultra-compact, unexpectedly lightweight form factor of our Maelstrom S12, and produces an amazing 640 out-the-front lumens using CREE's latest XM-L emitter!
CREE XM-L
The XM-L emitter in the X10 is CREE's latest LED technology, showcasing higher efficiency levels in a small package. Since the XM-L is physically smaller in size than the SST-90 emitter found in our Maelstrom S12, this gives the X10 a more ''focused'' beam spot, letting you see farther, even with fewer lumens!
Dependable and Intuitive
The Maelstrom X10 features the current and thermal regulation found in our S12. This means it can take serious abuse and be exposed to harsh conditions, but it will automatically control its output to protect its own guts. That means you don't worry about your light - you just use it.
The X10 is also powered by the same 26650 lithium-ion rechargeable battery used by the S12. But, the X10 will run for even longer - 1.8 hours on High!
And, finally, the X10 uses the intuitive interface found on our S12 - a simple pressure plate tailcap that gives you the option of momentary activation, locking it on, or locking it off.
CREE XM-L
