ebow86
I think I already know what the answer is going to be, yes right?. Reason I ask is the gap between the body and bezel of surefire lights vary quite a bit when using malkoff dropin's, I used to have an M61W and it created a very thin gap in my 6P, which was perfectly normal, however, when installed in my G3 the gap was absolutely huge, even when cranked down. I tried to avoid cranking down too hard because the G3's have a very thin tube of metal than runs the length of the tube, and when the dropin is cranked down it's puts alot of pressure on that thin tube of metal, which could possibly either break loose from the body after time or the dropin could just slightly bend the very edge of the thin metal tubing, never had it happen so I don't know the probability, since I swapped the M61W over to my 6P. I tried to warn of the possibility of this in another thread but my advice fell on deaf ears.
Anyway, I was toying with the notion of getting a new M61WLL for my G3 for a long runtime light but then it struck me that more than likely I will still have to deal with the huge gap I did before with the M61W. So I figured I would ask you guys about it even though I have a pretty good idea what you're going to say.
