first (~ serious) use of poor man\'s run-time meter
Thanks to Doug Owen I now have a working run-time meter (see this post for details).
After a few purely gratuitous amusements with the magic film and various photo resistors/ CdS cells, I thought I might at least try to use it seriously /ubbthreads/images/graemlins/smile.gif
Anyone tried the panasonic "Power Edge" AA's (zinc-nickel primary cells) ?
A search on them didn't yield anything, and they've only justed appeared in France, as the latest thing for digital cameras.
I compared them to Energizer e2 AA's, at light & heavy loads, as they are apparently designed for heavy load uses (low internal resistance?).
Low load: home-made voltage-regulated boost circuit for three 5mm white LED, fed by 2 batteries and set to 30mA on the new batteries. The resistor settings for the different batteries was different because the panasonics have a higher
no-load voltage (I measured ~1.85V but with .1 differences between cells /ubbthreads/images/graemlins/confused.gif)
High load: BB400 & 2 white emitters, also 2 batteries.
Results:
low load
energizer 14 hours & 12 mins
panasonic 15 hours
high load
energizer 46 minutes /ubbthreads/images/graemlins/frown.gif
panasonic 79 minutes /ubbthreads/images/graemlins/smile.gif
FYI, in case anyone wanted to know:
- I payed the equivalent of 5$ for the 4 panasonic
- home-made circuit is about 60% efficient in these conditions
- it regulates down to about 1.6V
-uh, yeah, the test was stopped automatically, I didn't hang around for 13h!
Results:
low load
panasonic 15 hours
high load
