Shooter21
So is the Quark series still the king of run times or is there another light with dominating run times?
it seems the only zebralight that has higher run times is the SC600. has anyone tested the 80 day runtime of the sc600Check the Thrunite Neutron series and most every Zebralight
EDIT: This only applies to 47s quark lights...it seems the only zebralight that has higher run times is the SC600. has anyone tested the 80 day runtime of the sc600
I've been running Panasonic 2900mah unprotected cells that are factory fressh and I get nowhere near the runtimes that Zebralight has posted. Running on high (500lm), with a fan blowing directly on the light, I usually get between 80 to 95 minutes runtime rather than the 120 that is suggested. Has anyone else had the same same findings ?
