As per title.
I'd like something significantly cheaper and (quite) a bit more powerful than a Fenix TK21, otherwise I'd probably buy just that from the local dealer (It seems reliable and great for my own needs, just too expensive).
A̶v̶a̶i̶l̶a̶b̶i̶l̶i̶t̶y̶ ̶i̶n̶ ̶ Cheap shipping to Europe is important.
Runtime and construction quality do not really matter (I already have reliable AA and CR123 lights for emergencies etc, although not very powerful). This will be a "toy" light, bought mostly for the "fun factor".
500-800 OTF lumens would be about right, which I guess means an XM-L LED (or perhaps an SST-50). Good throw desired but not required, but it shouldn't be all flood.
Beam quality is important (no more rings please!). OP reflector desired (but probably not that important with large die sizes, like XM-L).
Neutral tint availability would be a great bonus (The Quark MiNi NW XP-G limited run edition is still the best light I own, in terms of tint).
Size isn't important, but being pocketable would be another bonus (in spacious pockets, obviously, since it'll be a 18650 light).
Waterproof, if possible (but not a requirement). It should be weatherproof, though.
No aggressive crenelations. Clip not required.
Should be safe to use with both IMR and LiCo-unprotected (aka ICR) cells.
(I'm not crazy enough to use unprotected LiCo cells, but the protection could always fail.)
You can also propose unregulated models, but they should have at least a low-voltage cutoff (over-discharge protection).
Thank you in advance for your responses!
PS. Long time on-and-off lurker (I've only posted on the marketplace), so I'm pleased to meet all of you.
I apologise for the complete lack of originality of this boring thread. ;-)
