cell chemistry for ANSI FL1 ?
kramer5150
Palo Alto, CA
Quick question... does the FL1 standard require manufacturers to use a specific cell chemistry for Lumen/lux measurements?
Some of my AA lights (particularly the 1AA) the difference in output can almost double when using eneloops.
thanks
rookiedaddy
A Place Called HOME
No. But it does required manufacturers to state the battery used in their FL1 test claim and/or based on the included battery.
Robin24k
Washington, USA
If a light comes with batteries, FL-1 testing is done with that type of battery. If the light uses CR123 but doesn't come with any, it can be implied that lithium primaries are used. For AAA/AA/C/D, you can also assume alkaline unless stated otherwise, since most consumers use alkaline.
