leon2245
- Joined
- Apr 4, 2008
- Messages
- 2,335
peak AA: I like that they're of higher quality, available in single output level, and are a little longer than the quark. The only thing that concerns me is they seem specifically made for specialized 3v lithium primaries & rechargeable batteries, & I'm worried that using normal lithium energizer AA's it will be underpowered- I've read that can degrade your tint & efficiency etc. Also can't get a pocket body in a Peak aa anymore (unless I spend $80 on their QTC), & would have to compromise power levels- a #4 instead of a #6. Archimedes helped me with the math & figured out #6 is 37 lumens with my battery choice, closest to my target of 30.
quark AA: So easy because they're made for 1.5v aa's, no power level decisions or leaving vacant threads to tailstand (comes in "pocket body" exclusively), & is a little thinner. I've read about their fit & finish issues recently, rattling, & loose threads/wobbly heads, which would be a concern operating a head-twist light (& not much price diff vs. single mode peaks!). Requires two twists for my on as it will be used at 25l mode the majority of the time, for the 8hrs runtime. I gather that's longer than Peak's power level 6, IDK about power level 4.
What do you think? Advice, or suggestions I haven't thought of would be appreciated. Dealbreakers: not tailstandable, hi-first, thicker than .75", shorter than 3", or not having a mode somewhere between 20-40lumens (which I'm not even certain power level 4 is). Splurge on the qtc?
Bring on a nice head-twist. I grow weary of looking down & seeing light shining through my pants due to unintended clicky activation.
