Yes. You should be able to use it safely--without burning out the emitter--in any LED light, regulated or un-. But if your switch is not robust, you may destroy the switch because the NiZn's low resistance will let much more current pass through it. I destroyed the switch of my Romisen RC29 II that way. Now I use an Energizer L91 1.6V primary cell.
