3Cylinders
- Joined
- Aug 12, 2011
- Messages
- 96
Can anyone compare these two lights as far as beam pattern goes? I understand that the Wiseled will run longer at the same (slightly higher) power level and is a bit smaller, but I'm mostly wondering if anyone can compare the beam pattern and throw of these two lights. The TK70 runtime seems to be a little less than advertised (or is at least misleading). If the Wiseled throws as well as the TK70, I'll probably get it if the discount is still available. The extra runtime is worth the money to me. Can anyone confirm that the 35% discount is still available? Thank you.
