Lumintop t15x
duro
Well received my lumintop t15x. What a nice light. Great value as well. I bought an extra extension and outfitted the light with two 18650 3000mah batteries. Finally, a light with no issues.
jhc37013
Tennessee
Are you using Ultrafire 3000mah? I ask because when I use them in my TD15X the output drops slightly because the battery can't supply enough juice.
For instance with the TD15X and a Redilast 3000mah I can do a ceiling bounce compared to my Eagletac T20C2 XML and the TD15X is brighter however if I remove the Redilast and put in the Ultrafire 3000 then the T20C2 is slightly brighter. This has been a common occurrence with any of my high output high drain lights when using UF 3000mah.
duro
Yes. While I know they suck, I don't have the same problem. I did a test by using 3 cr123's, the beam looked the same as If I were using the 2 ultrafires. I know there are some bad ultrafires everywhere. I got mine from lighjunction.
