I've never been impressed with any of the headlamps from the 'name brand' headlamp manufacturers; Petzl, Black Diamond, Brunton.
I've not looked into their products recently, but in general, none of them make a regulated, wide range (meaning modes or levels), light with a neutral tint. They stick to an archaic 3xAAA battery configuration when 1xAA is just as much power but more compact and usable, because they're too cheap to create a driver that would use a lower voltage and provide greater output ranges at the same time, and provide regulation. I suspect they avoid regulation because they want to be able to advertise ridiculously long run-times, while not telling you that after the first couple of hours you barely have any useable light.
If you're serious about getting a high quality headlamp, forget about these and get a Spark, a Zebralight, or a Fenix. Right now Spark and Zebralight are neck and neck for the best ones on the market, with Fenix running a distant third. When they start using neutral emitters and improve their run times, they'll close the gap.
