SSC P7 driver for 4x 18650 batteries
aalto
Latvia
Hello!!
I need a little help to make my flashlight! I have got SSC p7 led and I have combined 4x 18650 batteries, capacity 4400mAh, voltage 8.4V. But I need driver to run LED with this battery pack. So can anyone tell me which driver would be good for? I eBay I found drivers for 5.5-12V input but they are designed to work with 2x li-ion batteries. This one - http://www.ebay.co.uk/itm/LED-Drive...lashlights&hash=item2c5aacb88d#ht_2099wt_1139
Please help :)
tre
Northern IL USA
I'm confused. 4x 18650 would be higher than 8.4V unless they are arranged so that 2 are in parallel and 2 are in series. In that case 4x 18650 cells would have a higher capacity than 4400mAh. Each one should be somewhere between 2200mAh and 3100mAh (for a total of 8800 on the low side). Which driver you need would depend on having that info. Also, make sure you are using quality cells. I hope the claim is not 4400mAh per 18650 cell. If so, just throw them in a garabage now because they are crap cells sold by a "fly by night" ebay seller.
aalto
Latvia
I think they are connected in series and parallel, probably they have 6400 mAh, because in ebay description for cells was written 6400, but in manual 4400mAh :/ So those batteries can run that driver ? Or i need another driver?
alpg88
that driver u linked should work just fine with 8,4v set up.
tre
Northern IL USA
It is sounding like it is a LiPo pack. I don't know anything about LiPo. Anybody else know anything about the LiPo pack?
PapaLumen
UK
Assuming 2200mah cells, if they are 2s2p then it would be a 7.4v (8.4v fully charged) pack with 4400mah capacity. (I have 4 of them) ala magicshine batteries. So you've got a bit confused there tre.
That driver should be fine and can be had cheaper if you want to wait for china post..
tre
Northern IL USA
The pack is a LiPo pack which is why the strange capacity.
PapaLumen
UK
No its not, he said made from 4x 18650. Also lipo voltage is the same as li-ion anyway.
aalto
Latvia
Thanks a lot for information!
And one more thing, where should add mode switcher button on this board? Can someone draw it on the picture, please?
Norm
Retired Administrator
Australia
No need for a power switching wire, switching is done by interrupting the power to the circuit via the normal power switch.
On a Maglite half press the switch and full click when the desired mode is reached.
Norm
tre
Northern IL USA
LiPo 18650 have different capacity than LiCo. That is all I was saying. I had a PM with a link to the pre made pack and it looks like it may be 4S
