Westernmdhardwoods
- Joined
- Sep 8, 2011
- Messages
- 27
I will start off by saying hello to all of you! I am glad there is a forum like this to help me with something I know nothing about!
I have been lurking for a couple days and decided to post up what I am looking for to see what you all can tell me!
I was getting all my stuff gathered up for the up and coming hunting season and realized my "bright" flashlight is nowhere to be found? I guess unless it turns up its time for a new one? I recently had a Streamlight 4AA Yellow Polymer flashlight before and it worked great and was the perfect size for what I need, but after reading on here it appears I can get a MUCH better light if I spend a few extra dollars....?
What do you think........heres my list.......
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__X__I will be mail-ordering or buying online, so this doesn't matter (Any Info on good buys appreciated)
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $25.
____Less than $50.
__X__Less than $100.(I would prefer $60ish)
____Less than $150.
____Less than $300.
____I have no limit.
____I'm flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
__X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
__X__Every day carry medium (4-7 inches). (I want the size similiar to my lost model the Streamlight 4AA Polymer, it wasnt too little not too big. It was easy to find in my backpack but still fit in my coat pocket)
____Holster carry.
____Big enough to need its own travel caseJ.
____I don't care.
____I don't know.
____N/A
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
__X__I don't know.
6) Manufacturer:
__X__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
__X__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
__X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
(I chose both because it seems most "better" flashlights are using this battery style)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
__X__I want to illuminate my entire backyard or a campsite (150-300 lumens). (I have a headlamp for everything I need to see up close..Ex: Climbing stands, checking backpack,etc...)
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__5-20 yards/meters (check out a noise in the backyard) (I still want to be able to look out and see something a good distance away if needed)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
__X__3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
(As much as possible without sacrificing too much. I will be needing this flashlight for finding my way through new pieces of land and would like it to be an all around bright light and last long enough for tracking blood trails)
____Not Important (A "night-stand" light).
__X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don't know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I don't care.
__X__I don't know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
__X__I don't care.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
__X__I don't care.(As long as its not overly heavy, I want something that when I reach into my backpack I know its there and can find it easily but I dont want it to weigh my backpack down)
____I don't know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
__X__Wrist/Neck Lanyard (Wrist lanyard would be nice but not overly important)
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
____Less than $25.
____Less than $50.
____Less than $150.
____Less than $300.
3) Format:
____Keychain size.
____Holster carry.
____I don't care.
____I don't know.
____N/A
__X__I don't know.
6) Manufacturer:
____I don't care.
____I don't know.
____I don't care.
__X__I don't know.
__X__I don't care.
____I don't know.
____I don't know.
____Holster
