110lm (AA), 260lm (CR123A), 550lm (RCR123)
more pics, info
http://www.jet-beam.com/links/pro/rrt0xml.aspx
more pics, info
I'm with the others: I think this is a pretty cool idea and I applaud Jetbeam for doing it.
They are making a light that can use:
1x RCR123 (well, technically you should be using an IMR, but you knew that, didn't you? :tinfoil
1x CR123
1x AA
It's using the latest and greatest emitter, and if we're lucky, they'll do a neutral run as they've done with a few of their newer lights. It has the popular RRT-0 interface (probably the new firmware with the ridiculous low).
As has been mentioned, an XM-L in a light with such a small reflector is going to be all flood, so that's something to think about.
Don't know if I'll buy one (I already have an RRT-0 and a TCR2) but I definitely like that JB went the extra mile and added the option to run it hotter and brighter for those enthusiasts who are comfortable doing so.
For those who don't read the fine print:
260 lumens using a cr123a primary cell
You only get 550 lumens using a rcr123 rechargeable cell.
It is also a very floody light so throw junkies stay away. It is going to seem like it has less output than the rating because the beam is not intense.
Geez, not sure if manufacturers should be putting large size XM-L emitters in such small flashlights?
Not only is it too floody, but when hi current draw is used, the RCR123 750 mAH won't last very long.
Hopefully they don't discontinue the R5 and S2 version as their website suggests?
XM-L emitters are more appropriate for medium sized flashlights and beyond like the new RRT-15 with a big 2 inch diameter head.
XM-L would do well in the 3/4 size 2x18650 M2S or M1x.
For a full size 3x18650 flashlight, the SST-50 is less energy efficient than XM-L, however with a hi current draw, the SST-50 still out-powers the XM-L.
I think they should match emitter sizes appropriately with flashlight head sizes, unless they deliberately want the RRT-0 to be all flood, and little throw...
