ballsofcottonwool
- Joined
- Sep 18, 2007
- Messages
- 11
carved up the rear of the housing to make room for an LFLEX driver
copper heatspreader cut from 14g (2mm) copper sheet.
Bottom contacts of the CREE XML removed with a diamon burr grinder in a rotary tool.
LFLEX driver was used as a template to mark holes on the copper heat spreader.
lfex connected up and stuck to heat spreader with supplied adhesive pad.
Driver is controlled by this tactile switch soldered to a length of 2 core wire and connections covered with heatshrink.
Reflector glued onto heatspreader, ready to install in minewt housing.
