dosei-45
I personally perfer lights with grip rings (such as the Surefire 6z, Fenix TK 11/12/15/21, Olight Warrior). The problem I have with them is that almost all of them also have rather sharp, scalloped "strike bezels" that makes pocket carry impossible (because they cut through your pants). I also can't stand the nylon holsters that most lights come with. I have found the Galco FLC flashlight carrier to be fairly useful. It hold the light by the body, and as such can hold a vast assortment of lights (since so many lights have the same body diameter of 1" or 25.4mm). But once again, those darn "strike bezels" quickly ruin anything they rub against. So my quest is to find lights that have grip rings but do not have strike bezels.
Desired features:
Uses 2 CR-123 batteries
Has several output levels (would like at least three levels plus strobe)
Has a grip ring
Does not have a sharp "strike bezel"
Has a strobe feature
Under $130.00
Greatly prefer wide flood style light over tight spot. I want it to illuminate as broad of an area in front of me as possible, I don't care if it has trouble lighting up a man-sized target 300 yards away.
So far, the only great candidate I've come across is the Jetbeam PC25. I really like everything about it, seems like the perfect light for me. The question is, are there any other lights out there that fit the bill.
Thank-you in advance!
Desired features:
Has a grip ring
Under $130.00
