brembo
- Joined
- Jun 14, 2011
- Messages
- 203
I am considering the mentioned dropin for a 6P that is getting bored for 18650 cell use. The light will likely end up with some Shao-tech GITD diffuser film as well, I want flood. My only concern is that the output will be limited, not in lumens but in runtime on a single 18650. The specs on the NB Linger state 3.6-6v while in regulation, and I assume the module goes into direct drive below 3.6. What kind of runtime can I expect to see without doing undue harm to my spendy AW cells? Is there a comparable Malkoff dropin? The current run of Malkoff is 80 CRI, BUT I could use two 18350s and potentially keep the light in regulation longer (right?). Mainly I'm curious about this high (90+) CRI business, wanna see what has so many people all stirred up.
