"Need Weapon Mounted Light: ~1 in. diameter AA Batteries".
sspro2340
Hey forum
I've been looking for some flashlights to fit on a Safariland RLS system
http://www.safariland.com/DutyGear/rls/
However I don't want to buy the light that comes with it just the mount.
I think the light that comes with it is under powered
Criteria
Length: must be under 5"
Width: must be between .970" (24.6mm) - 1.060" (26.9mm) in diameter
Weight: not concerned
Price: Around $40-60
Momentary press
Technology: LED hopefully a Q5 R5 (not sure what the difference is)
Shock proof (as it is being mounted to a weapon)
BATTERIES: Would strongly prefer NOT to use cr123
AA AAA common cheaply found battery system desired
Runtime: Around 60 mins is the MIN 90-120 is preferred on high
Spill vs throw, don't really care
lumen: around 100
So far the only light to almost fit my "requirements" is the ITP SA1
Hope you guys can find some other suggestions
-Thanks
Imon
The Lone Star State
Re: could use some help finding a flashlight
You could go for the Maglite XL200. I dislike the 3xAAA config but for your requirements - under 5" and ~1" in diameter you can't pack much electrical potential energy with AAs (unless you use a 14500).
sspro2340
yeah i saw the xl50s and 200s but i was unsure if they would last while being mounted on a gun
TyJo
USA
I don't know much about this stuff but I don't think you will find a reliable solution in this price range. I don't own any Surefires, but if I needed to mount a light on a gun I would (unfortunately they only have one 2xAA model that I am aware of).
sspro2340
still looking, might be willing to go a little more $ wise for the light
TyJo
USA
I recommend editing your title of the thread to something like "Need Weapon Mounted Light: ~1 in. diameter AA Batteries". To do this edit your first post and click "go advanced."
sspro2340
thanks man, I'll try it out.
KenAnderson
Vancouver, WA
Actually I'm not sure it can be done. A single 1.2V AA doesn't have enough juice to generate 100 lumens for 60-90 minutes. A single CR123a does but it's out of the question. The size limitation may make this one difficult. I have a Novatac with a 17650 that will run for 4 hours at 100 lumens and the right size, but it's not a commonly found battery.
T-roc87
Wisconsin
The zebralight sc51 claim 100 lumens for 2.4 hours running off of a single eneloop battery! It also can go up to 200 lumens for .9 hours. Its worth looking into.
