Just was wondering if anyone might know what other Surefire tail caps are compatible with the LX2.
I've successfully replaced the emitter with an XML, which works pretty well for a while.
However, it seems the electronics in the tail cap are interfering with the driver I used and causing some conflicts on mode changes.
The original tail cap is disassembled and I'm in the process of hand grinding a McClicky switch to fit but would really like to know if there are other options out there for some Lego action. Maybe I can avoid the hand grinding if there's a tail cap with a switch already out there that will work with the LX2.
Any thoughts or suggestions ?
