You might be in the H2 (100lm) instead of H1(200lm)? Try to double clicking to toggle back and forth.
thanks very much
my initial impressions are that i like it, the tint is very good and it's just as small as i'd hoped
i am a little disappointed in the output on high, i thought it would be brighter than my ld10 r5: it isn't. the ld10 r5 throws much further and looks a lot brighter which means that the r4 ld10 will be a lot brighter. i thought this was the brightest 1xaa available
still going to be my new edc as the output is ok and the size/modes are really good
thanks very much
maybe he got a brighter one than i did
Return it for another one.
-Do you have fresh full battery?thanks very much
-If you are not using Eneloops, you won´t probably get the most out of it.
-Try cleaning surfaces between battery positive & head, battery negative & tail + tailcap & body. This helped for me!
Lots of people perceive a light with a more intense beam as having more output. The LD10 has a more intense beam but it does not have more output. In other words, the SC51 is a more floody light than the LD10. The LD10 concentrates less lumens into a more intense beam while the SC51 has more lumens flooded out into wider beam. You should notice the hotspot on the SC51 is larger, the spill is larger, and the spill is brighter. The SC51 does put out more lumens.
On another note, the LD10 R5 has more output (lumens) than the LD10 R4. The difference is that the LD10 R4 was measured at turn on (or possibly used emitter lumens) while the LD10 R5 is measured using the ANSI standard OTF measurement for output.
update:
got another sc51 as a gift for someone else and it's visually brighter on high than mine, bit of inconsistency from zl
and yes i fully understand the modes and no i don't care that mine is a bit less bright on high/high
