Is it that hard to redesign the reflector with the xml so the end result is to keeping or increasing the throw on a throw light? Or are they just being cheap?
I just wish that more optics are being used to get throw without a huge head to hold a big reflector.
The LED emitters may be reaching the ceiling in their development?
The LED emitters are getting larger in size, to increase efficiency, and produce more light, as the XP-G and XM-L does.
However, their surface area is increasing at a much greater rate than their lumen output.
The XR-E R2 is roughly 1mm x1mm.
The XP-G R5 is roughly 1.2mm x 1.2mm.
The XM-L 2mm x 2mm.
SST-50 2.25mm x 2.25mm.
Thus, their maximum surface brightness is decreasing.
Surface brightness is the main factor in determining the throw.
To compensate, a large diameter reflector can "capture" more light, and focus that light into the hotspot, to produce a brighter and more intense hotspot to increase the throw.
Because the XM-L has a reduced surface brightness, if we increase the diameter of the reflector to capture more light, and focus that light into the hotspot, then we can further increase the intensity of the hotspot to produce more throw.
This is how the Olight M3X XM-L, the Eagletac M3C4 XM-L with 394 meters throw, and the Thrunite Catapult V3 XM-L with 402 meters throw works - as measured by Selfbuilt.
M3X
http://www.youtube.com/watch?v=ASH0WXioYe8
M3C4
http://www.youtube.com/watch?v=RpyyIFWMT7c
Catapult V3
http://www.youtube.com/watch?v=y8YwnsBExIM
In the videos above, note how the Catapult V3 has a narrower spill, yet a much brighter "corona".
So if the reflector diameter remains the same, while the reflector depth increases, we say that the depth to diameter ratio increases.
A deeper reflector ratio diminishes the width of the side spill.
However, a deeper reflector ratio also causes something like "diffraction" of light to occur, creating an additional band of light around the hotspot called the "corona".
A deeper reflector ratio will not give more intensity of light in the hotspot, nor more throw.
A deeper reflector ratio increases the corona.
The spill, is light that fall directly on the surface, from the emitter itself.
The brightness of the spill is determined directly by the brightness of the emitter.
One advantage of a larger die size of the XP-G and XM-L is that it does give a larger hotspot.
A larger reflector diameter does not result in a larger hotspot, but a brighter hotspot.
Summary:
Thus the die size determines the hot spot size.
The die surface brightness determines the brightness of the hot spot, hence the throw.
The reflector diameter collects the light and focuses it into the hot spot, to further increase the brightness of the hot spot, and hence the throw.
The reflector depth to diameter ratio actually makes the side spill narrower, but increases the "corona" - an auxiliary band of light surrounding the hot spot.
The lateral spill of light, comes from light that is falling directly from the emitter itself, thus the spill brightness depends on the emitter brightness.
If we calculate the surface brightness of many flash lights, we find that the surface brightness is actually very close.
For example:
Olight SR90 SST-90 @ 2200 lumens divided by 9 mm sq = 244.44
Jb RRT-3 SST-50 @ 1200 lumens divided by 5 mm sq = 240
Eagletac M3C4 XM-L @ 1000 lumens divided by 4 sq mm = 250.
With such similar surface brightness, how do we explain the SR90's 634 meters of throw, versus the M3C4's 394 meters of throw, according to Selfbuilt's data?
What really determines the throw in these lights is actually the bezel and hence reflector diameter.
For example, the SR90's bezel diameter is some 100 mm, versus the M3C4 XM-L's 61 mm.
Thus to answer aau007's question, it is actually very easy to redesign the reflector for the XM-L emitter, but you will end up with a larger diameter reflector to compensate for the fall in surface brightness of the XM-L emitter!!!
For yowzer, with present technology, an XM-L emitter with reduced surface brightness, given the same size diameter reflector, it won't be possible to maintain the throw, let alone increase that throw.
If an engineer could increase the brightness of the emitters, while maintaining the overall dimensions of the die, then he will be a rich man...
For more information on throw, you can search cpf, esp members like Saabluster, Dr Jones, Ra, walterk & gcbryan - they understand this complex topic very very well.
I've never been able to get past the first few sentences of their complex science articles...
