Does anyone have any info on dismantling a Streamlight Twin-Task 3C LEd flashlight? I'm looking to remove the 6 white LED's and replace them with Red ones (either 6 high intensity, or 3 indicator-style low intensity / 3 high intensity reds). Either way preserves the button function, though with 6 high intensities leds it would probably be preferred to just have 2 modes if possible (All 6 Reds or the Luxeon Rebel on)...
Anyway.. I cannot get this thing apart - You can remove the end cap and reflector easily, but there's a threaded barrel beneath it that appears to hold in the light which no amount of force will turn. Also appears that the entire head is separate as well, but same story. Are these things loc-tited or welded? I've even used tools on the inner barrel with no luck (careful not to damage the cap threads).
Anyone gutted one that has some experience with them?
K9
K9
