Recently, I have built a battery charger and have used it to charge my battery packs for a month. I would like to share the joy of DIY with you guys.
Home made PCB.
Assembled PCB
The IC, Max1757/8, will heat up to about 70C. I glued an Al slug with thermal epoxy on the top surface of the IC to conduct the heat to the Al case.
The yellow LED glows to indicate the charger is in Constant Current Mode, the green LED for Constant Voltage Mode and the red LED for Fault Mode.
No LED is on indicate that the charge cycle is completed. The IC is selectable to charge 1 Cell, 2 Cells, 3 Cells or 4 Cells. I fixed it only to charge 2 Cells. The maximum charge current is 1.5A. It takes about 3.5 hours to full charge my 2S1P 7.2V 2600mAH battery pack.
Home made PCB.
Assembled PCB
