____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__x__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
__x__Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I'm flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
__x__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
__x__Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don't care.
____I don't know.
____N/A
5) Emitter/Light source:
__x__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
__x__I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
__x__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
_x___I want to navigate a dark room or read a map (0-10 lumens).
_x___I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
__x__Less than 1 yard/meter (reading, other close work)
__x__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__x__5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
__?__Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__x__Slightly Important (Walks around the neighborhood).
__x__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don't know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
_x___I want a tail mounted switch (found on the majority of today's high end lights).
__x__I don't care.
____I don't know.
__x__A simple on-off with only one output level is fine for me.
__x__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
_x___I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
__x__I don't care.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_x___I don't care.
____I don't know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
__x__Less than $25.
____Less than $50.
____Less than $100.
____Less than $150.
____Less than $300.
3) Format:
____Keychain size.
____Holster carry.
____I don't care.
____I don't know.
____N/A
____I don't know.
6) Manufacturer:
____I don't care.
____I don't know.
__x__I don't care.
____I don't know.
__x__I don't care.
____I don't know.
_x___I don't care.
____I don't know.
____Holster
