jtice,
I've often wondered about this myself and have recently been looking into it seriously. I've discussed the matter via PMs with CM. Both he and I have experimented with different optics and reflectors.
First let me say this and I hope that someone chimes in if I'm wrong. You want THROW. Is this all you want. I mean, are you looking for a strickly long range light with no sidespill? I think that getting throw will be more dependent on the optic or reflector that you use. Of the hosts that you listed above, I'm gonna say that you could narrow your selection down to one of the two McLuxes and using a 1W high dome. It's my understanding that the 1W luxeons allow for a more concentrated beam, simply due to the fact that the source of light in a 1W is 1/4 the size of the light source from a 5W.
The PR has developed a reputation for being able to concentrate a beam and still provide for sidespill making it a very useful beam.
I, myself, have experimented with the low profile fraen optic. My experimentation has been limited to messing with KL1's, but it is my understanding that the LP Fraens can be made to work in a McLux head. In using the LP fraens, I've found that this particular optic is very efficient. In comparing two virtually identical KL1's, one with an NX05 and the other with the LP fraen, I found that the fraen equipped KL1 put out noticeably more light.
The beam characteristics of the Fraen LP are such that, and this is a little hard to describe, the sidespill is all but eliminated. All that is put out is a hotspot. That statement is a little misleading though. It isn't a needle beam. The beam does grow usefully over distances making a light equipped with the fraen a great long range light. I have a KL1 that has been overdriven to 700mA and is equipped with an R2K and a Fraen LP optic. This head will easily out throw every other 1W I have. This includes a 3D
M@g mod I did direct driving a Q3J using a regular Fraen optic.
Another option that you might want to consider is using the McLux PR head with a 30mm optic. You will have to turn down the optic to make it fit. CM modded a KL3 with one of these running an overdriven 1W and he said that it threw as far as a 2 cell surefire.
My next project is going to involve the McLux PR. I've heard plenty of good things about this setup. Great throw and good sidespill. It should be easy too. I'd go with an R2K being driven by a downboy 700. The reason that I'm planning on using an R2K rather than a Q3J or any other 3 is because I've found that the warmer tinted LED throw better outdoors. It looks to be closer to sunlight.
I know I've just been babbling. I hope that you got something useful out of all of this.
On a last note, you said small. How small? McLux or McLux PR? Really small would be McLux with Fraen LP on an E1e body. Since you'd be talking about driving it with a single 123, you could try an R2H or Q3J to maximize runtime and drive it with a badboy 700. I only make mention of the E1e because I'm not wild about Krolls and stick with the Surefire bodies.
