Mattaus
Hi all,
So I bought a cheap host from DX (actually expensive by DX standards) with my sole intention being to modify the hell out of it for my own personal amusement. Something to do basically.
Well I can say I've never pulled apart a flashlight before other than my first mag mod (which went very well). Seen as modifying the light I have bought now is not as common as the maglites I would like to ask for some help. Nothing complicated of course!
As you can see below I have removed the head and tail from the single 18650 light. I want to get the pill/driver/led/reflector out of the head and the switch out of the tail cap. The goal is to build a custom pill/led/driver combo for the head and if possible install a better switch in the tail. The problem is I have only a small inkling as to how I can remove the existing components and it's all guess work. I don't want to break anything if I can help it…
The pill – desolder those 2 small solder tabs and the driver board should pop out yes? What about the rest? Pliers and some twisting to screw the pill out?
The switch - I'm guessing those 2 small holes can be used to remove the plastic cover to get into the switch, but is it the same as the pill in the head? Screw in?
Apologies if this is ultra noob-ish or blindingly obvious. I just want to do a good job and not screw things up beyond repair!
Any assistance would be highly appreciated.
Cheers,
- Matt
Cheers,
- Matt
