HDS Systems
Page 5 of 46 FirstFirst 12345678910111215 ... LastLast
Results 121 to 150 of 1367
Thread: MBI Core Ti - (world's thinnest??) Titanium Flashlight Pendant - (work in progress)
  1. #121
    Light11's Avatar
    Nov 2009
    The Great Northwest
    Default Re: MBI Core Ti - (world's thinnest??) Titanium Flashlight Pendant - (work in progres
    +4
    it would look better with a flush LED.
  2. #122
    Flashaholic SixM's Avatar
    Sep 2009
    SE MI
    I prefer flush, but would buy either. I hate to say it, but I don't care for the MBI on the button. If I bought one of these I would wear it daily around my neck, along with my crucifix, and would like a plain, clean, neutral design, or at the most my initials or even a cross design (two-fer one there). I totally understand and respect you having the MBI on there though, just throwing out my thoughts.
  3. #123
    Apr 2008
    Cleveland,Oh
    I would agree the flush LED and the blank button are more aesthetically pleasing.
    Can you please slow down a bit with the new light concepts? I can only work so much overtime in a given period.
    Great spirits have always encountered violent opposition from mediocre minds.
    -- Albert Einstein
  4. #124
    Quote Originally Posted by Bigmac_79 View Post
    I like the look of the Core Ti better with the LED fully recessed, but if the beam pattern and output are better with the LED poking out a bit that would be worth it.
    Thanks Mac,
    With the right LED, I think beam pattern and output should be mostly the same.
    Quote Originally Posted by Got Lumens? View Post
    Guy,
    The recessed or flush(slight protrusion 0.25mm) looks much better, IMO.
    Another idea for Ver 2(or1). Why not have two switches, one small slide switch on the side for constant on, and the momentary button as you have now.
    GL
    Thanks GL,
    For the record, flushed is my preference too, was just showing a quick custom version.
    I wish I could send everyone 2 each just so you could compare.
    The only functional advantage of slightly protruding, is that If/when we can add a circuit, slightly protruding is far more visible and could easily double as a "see me" kind of light (in flashing mode) but we can cross that bridge when we get to the circuit version.
    Re: Switch on the side, its possible but not sure if would be a good thing for waterproofing, or the look?
    though it does provide the extra advantage of no accidental on if you were to keep one in your wallet.
    The current button is very flush with the body and rather firm.
    I've not had any accidental "on" happen but I could imagine it's possible if you sit on your wallet,
    though I would not recommend that.
    Based on the protos I'd say very little chance of accidental on in keychain/neckchain use.
    If its a necessity to have it, very happy to consider it but perhaps version 2 in combination with the circuit?
    tgwnn
  5. #125
    Quote Originally Posted by BVH View Post
    +1 for flush or recessed.
    Quote Originally Posted by Zeruel View Post
    +2 flush or recessed.
    +1 for blank button.
    Quote Originally Posted by Morelite View Post
    +3 for flush
    Quote Originally Posted by Light11 View Post
    +4
    So does this mean you prefer a flush LED ?
    Flush it is!
    Quote Originally Posted by SixM View Post
    Thanks SixM,
    I appreciate the kindly worded feedback.
    Understood! I wouldn't expect you to have my personal monogram on your shirt either (unlike that Ralph guy).
    If the MBI was small enough to fit on the 3.5mm side (though seems unlikely) and not obvious, then, would you find it ok?
    Everyone one else, please dont worry about offending me, I'm really happy to have your honest feedback.
    Quote Originally Posted by jabe1 View Post
    Yes, I should be careful not to overwork you guys
    tgwnn
  6. #126
    Apr 2006
    USA
    Here's an idea:
    Earlier, you had mentioned perhaps using two CR2016 cells, to get 6 volts.
    You stated this would drive the LED very bright.
    Yes, indeed, it certainly Would be bright !
    PLUS -- it would give people like ME the opportunity to use a single CR2032 cell, instead.
    I already know (from converting numerous Photons and Fauxtons),
    that a single CR2032 battery driving a 5mm LED gives PLENTY of light !
    ( for MY purposes. Your mileage may vary )
    We would LOVE having that Flexibility with this cool little beauty.
    As you may have noticed, some of us prefer Lower Light Levels.
    Just a thought.
  7. #127
    Sep 2009
    SE MI
    Quote Originally Posted by the_guy_with_no_name View Post
    Thanks SixM,
    tgwnn
    Yes on the side is good, or even on the back is fine as long as it hangs consistently in the correct orientation.
  8. #128
    I also think that would be preferable if possible.
  9. #129
    Quote Originally Posted by Burgess View Post
    Here's an idea:
    Just a thought.
    Thanks Burgess (I have noticed)
    I've submitted a revised design, and approved up to 1 or 2mm longer/wider (but not thicker) to accept either 2x CR2012 or 1x CR2025, as the standard and it "should" pending test accept 1x CR2016, 1x CR2032, 2x CR2016
    The CR 2016,2025,2032 were all available at the 7/11 I stopped by this evening so they must be widely available.
    Thanks
    checking, will let you know soon as confirmed.
    The main challenge now is finding a decent led (that is flat).
    The one used in the manufactured proto are not too bright & pure flood (not focused at all).
    The ones I filed down from 5mm leds still keep their lens/focus, are bright and work well but I don't want to be custom filing hundreds of leds, I'd much rather find a bright, high mcd, flat led.
    (If anybody knows a good source for those, please let do me know).
    I've tried a small cree which is bright, but will need extra housing & custom tiny reflector/lens, so I'll have to hold that led choice for a future version.
    Updated the internal layout a little to improve space usage as well as implemented the slightly angled hole, and some other fine tuning (so its easier to open).
    One thing I noticed is that even with the straight (squarish) hole in the proto, it seems to hang straight, even when the chain is positioned to the left or right.
    tgwnn
  10. #130
    Flashaholic* Cataract's Avatar
    Apr 2009
    Montreal
    +1 more on flat/flush LED
    +1 on accepting different batteries
    I would prefer if the MBI name was VERY discrete and would not mind if it was not there at all, since this definitely fits more the looks of a piece of jewelery. (I'll show off the MBI on my torpedo proudly to make up for it )
    Could the button cover be exchangeable or modifiable? by the user? It would be a very practical way to personnalise the Ti
    Cataract, Shiny things specialist.
    Google Map for CPF
  11. #131
    Flashaholic* bigchelis's Avatar
    Oct 2008
    Morgan Hill, CA
    Plus one on Flush.
    Why not make it a mule type of design which will be 100% all flood.
    No matter what you make, sign me up for 1 at least.
    bigC
    Surefire 6P with Malkoff M60 simple, bright, efficient.
  12. #132
    Flashaholic Acid87's Avatar
    Glasgow Scotland
    Default
    Flush would limit the abuse the LED might incur in pockets if this beauty does go into someone pocket.
  13. #133
    Quote Originally Posted by Cataract View Post
    Thanks for the feedback.
    Its possible the button could be replaceable. Not exactly sure what you mean by modifiable though (something different to just changing the button?)
    Blank should be a possible option.
    Quote Originally Posted by bigchelis View Post
    Plus one on Flush.
    bigC
    BigC,
    Thanks so much for the feedback and interest.
    100% flood is the easiest thing to do in terms of led choice, but so far in my tests,
    when the lumen output is low, pure flood seems useful/practical in dark situations with little/no ambient light.
    Not quite enough to find something on the floor of the car unless you hold the Core Ti near the floor.
    Though it will depend on final lumen output, so far I've found with even a modestly focused beam, it's a little more practical as an all purpose type of light.
    Quote Originally Posted by Acid87 View Post
    Yes, agreed
    tgwnn
  14. #134
    I've been considering one of the new Osram SMD angle LED's for a little project I've been working on, but have yet to order any. On paper, their stats look very impressive:
    6200k @ 80CRI: http://ca.mouser.com/ProductDetail/O...otfSEQKQ%3d%3d
    5600k @ 80CRI: http://search.digikey.com/ca/en/products/LW Y87C-T1U1-3C5D/475-1055-2-ND/565007
    At 1.25 lumens, I don't think they're exactly what you're looking for though.
  15. #135
    Quote Originally Posted by calipsoii View Post
    5600k @ 80CRI: http://search.digikey.com/ca/en/prod...55-2-ND/565007
    Thanks very much for that.
    I was looking at some of the Osram SMD's yesterday (similar size to the above but much brighter, and also the Oslon SX) but the datasheet's are not very useful at <50ma, so the only way to be sure is to get some sample's and test.
    In terms of waterproofing though, I think a through-hole (standard 5mm type led) will make it easier to achieve that.
    tgwnn
  16. #136
    Battery/Led choice and size implications....
    Please give me your feedback
    In order to use a CR20xx series of battery (eg. CR2012,2016,2025,2032)
    we will need to adjust the dimensions slightly...
    Now: width 22mm, length 32mm
    Proposed: width 24mm, length 35mm
    Can you let me know this is ok for everyone?
    Thickness will be the same.
    If we use a CR16xx series battery, we can keep the current size,
    but the CR20xx are much more widely available and provide the option for more brightness without needing more thickness.
    A) eg. 2x CR2012 = 2.4mm
    B) eg. 2x CR1616 = 3.2mm
    With A) we can keep the thickness around 3.5mm~3.6mm (definitely under 4mm)
    With B) we would be at roughly 4mm~4.5mm
    The current prototype (in the photos) uses 1x CR1616 and is about 3.6mm (with internal room to spare)
    Thanks,
    tgwnn
  17. #137
    Feb 2003
    Texas
    CR20xx gets my vote
  18. #138
    Quote Originally Posted by rdf View Post
    CR20xx gets my vote
    Thank you!
  19. #139
    Flashaholic* Got Lumens?'s Avatar
    Mar 2011
    Champlain Valley
    Thanks,
    tgwnn
    Guy,
    No side by side battery options?
    That would keep it under your 4mm target thickness.
    GL
  20. #140
    *Flashaholic* kaichu dento's Avatar
    Apr 2008
    大和/Alyeska
    Then this option would get my vote!
    Marduke - Solitaire...I've seen matches which are brighter AND have a longer runtime. 光陰矢の如し
  21. #141
    Guy,
    GL
    Thanks GL,
    Nothing small enough that makes sense.
    eg.
    CR927, 1025
    both will be thicker than 2x 2012 or 1x2012
    I looked at the 1.5V cells as well...
    we'd need to use 3 to make up the voltage,
    and very little benefit in thickness for a tradeoff in capacity
    tgwnn
  22. #142
    Quote Originally Posted by kaichu dento View Post
    Thanks kc.
  23. #143
    Mar 2011
    Champlain Valley
    PM sent.
  24. #144
    PM sent.
    Hi GL,
    Thanks.
    My CPF inbox/outbox is full
    Let me delete something so I can reply
    tgwnn
  25. #145
    Glasgow Scotland
    Default
    I agree with the 20xx these batteries are available everywhere and I have a Petzl emergency headlamp that uses 2032 I believe.
  26. #146
    Jul 2011
    England
    Have you seen this thread? http://www.candlepowerforums.com/vb/...w-much-current someone there tested a couple of button cells and they performed poorly with fairly low current, how much current is your led going to be drawing?
    I cannot pretend to feel impartial about tint colours. I rejoice with the brilliant ones and am genuinely sorry for the poor browns.
    ~Sir Winston Churchill
  27. #147
    Thanks Acid.
    Quote Originally Posted by JacobJones View Post
    Thanks JJ,
    We dont need much power for the led.
    I've tested multiple combinations and it does just fine with any of the 20xx series cells, though brightest when using 2 of them.
    We only need a few mA.
    tgwnn
  28. #148
    Apr 2009
    Montreal
    I like multiple battery options. I prefer 20XX, the width and length difference are negligible and I can get those virtually anywhere.
    Could we stilll put just one 20XX or one 16XX with this configuration?
    Google Map for CPF
  29. #149
    Yes,
    you will be able to use at least either:
    2x 2012
    1x 2025
    and very probably also these combos
    2x 2016
    2x 1616
    1x 2032
    1x 1632
    maybe these too
    1x 2016
    1x 1616
    tgwnn
  30. #150
    Apr 2009
    Montreal
    That's a lot of possibilities! I have lights for which I need a reminder card on how to program or the runtimes... Never had one for which I need a reminder card on all the batteries it can take! Me Likes!
    Google Map for CPF
