DEFT-edc, unfortunately, can't run on primaries or reach 500 lumens. If you are fine with just 18650, it will give you an insane amount of throw (~40k lux) for its size.
ArmyTek Predator... Beastly tactical thrower with maximum range of ~250 meters and effective range of ~150, still doesn't break the 500 lumen barrier.
Xeno G42 puts out something like 26k lux, so around 300 meters of throw, but it doesn't go up to 500 lumens, either.
To be honest, for XP-E or -G, unless you are looking at multi-emitter lights which, by the way, aren't geared for throw, you aren't going to reach the 500 lumen mark. You are going to have to move towards SST-50 or XM-L territory for that to happen. But that's where the fun begins.
LumaPower Signature LX "Power Pack" with XM-L supposedly does 580 lumens. (I'm not sure if this is at the emitter, OTF or ANSI) Combined with its large head, it should give an excellent throw.
ThruNite Scorpion V2 with turbohead. 725 lumens initially and 640 ANSI lumens with a single 18650. Throws out to around 270-280 meters, according to selfbuilt's review, so the effective range should be around 200.
ThruNite TN11. 750 lumens initially using a single 18650. With primaries or RCR123As, the figure should be a bit higher, around 800 initially. With 2x18650, 3 or 4xCR123A or 3xRCR123A, this sucker puts out 830 ANSI lumens. According to ANSI/NEMA FL-1 standards, it supposedly has 355 meter throw when running on full power with extra batteries, so 250+ meters of effective range. It edges out even TK35 in both output and throw. If run on 1x18650 or 2xCR123A, it should have more or less the same performance as Scorpion V2 with turbohead.
