inrealtime
*Was on hold for a trade, but it fell though, so for sale again.*
From L to R in picture below.
1.Aurora SH-034 Emitter replaced with Neutral T6 xm-l & 3 mode switch H-M-L.
Uses a 16340 for max brightness. $45 Shipped SOLD
$105 shipped for the last 2 remaining lights
I have been asked if they include a 18650, so I will include 1 each. These are what I use with the lights. The are from a Panasonic laptop battery. NCR18650 2900 mah. The grey label ripped when I removed the glue holding the batteries together, so I wrapped them with clear tape. They charge great & work wonderful
2..Copy & Paste from where I bought: http://www.cpfmarketplace.com/mp/archive/index.php/t-251586.html
Aurora CREE V6, modded with SST-90 de-domed, solarforce pocket clip, trustfire tr-801 tail cap
1 mode, Fraen reflector, runs on 18650 or two cr123a batttery. (Do not use
two rechargerable lithium cells like the 16540 or AW/IMR 16540.) Host exterior was lathe turned
down for a trimmer and lighter body, will tail stand. Body allows finger grip hold. Very floody,
will be brighter with cr123a battery, however should be hand held when using continously on
high to help remove heat. $75 shipped
3. Trustfire Tr-801, modded with a T6 XM-l a Brass Pill & upgraded driver. Had this one made for me in Direct Drive & as bright as possible. Ended up getting 3.8a at the tailcap. Uses 18650
$ 49 shipped
Here is a link from where light 1 & 3 were modded & purchased http://www.cpfmarketplace.com/mp/showthread.php?251566-49-Aurora-SH-034-XML-Neutral-49-SolarForce-XML-Neutral-49TR-801-XML-Neutral
4. P-Rocket PLI SOLD
$ 49 shipped
