New light from Tank007 - The TC07
jimmy1970
Brisbane, Australia
Hi Guys,
Any body seen this new model from Tank: The TC07??
TC07 Rechargeable LED Flashlight
Features:
1. Perfect option for police use, searching and outdoor activities
2. Throws beam of 300 meters
3. Hard head made of high-cost 304# stainless steel
4. With memory function, anti-reverse and high efficient driver circuit of constant current.
Specifications:
Model number
TC07
Exterior Color
Black
Material
Made of durable T6 aircraft-grade aluminum
Treatment
Premium Type III hard-anodized anti-abrasive finish
Reflector
Vacuum coated aluminum optical reflector
Lens
High-efficiency optical lens
Lamp
Cree XM-L T6 led originally imported from the USA with
life span of 80,000 hours.
Max Brightness
800lumens
Output Level
Five mode (High-Med-Low-Strobe-SOS)
Power Source
1x18650 Li-ion battery or 2x CR123 batteries.
Input Voltage
3.0V~13.0V DC
BurnTime
High light:
Med
Low light
Strobe
SOS
800LM
180
20LM
X
X
>1.5hour;
>6 hours
>50hours
Throw Beam
300meters
Water proof
IPX8
Switch
Button switch in the middle
Impact Resistant
Anti-drop height of 1 meters
Size
23.8cm(length)*2.6cm(diameter)*4.6cm(head diameter)
Weight
311.3g(excluding batteries)
Accessories
Lanyard, O-ring, gift box
Warning: XM-L T6 is high power and high brightness LED, for which it gives much more heat than other leds. We suggest that the highest lighting mode be switched to medium or low lighting mode after being used continuously for 20 minutes.
