Hi all, new candlepowerforum member here. I'm in the market for a $50ish LED flashlight for both general home use and for camping/backpacking. I already have a headlamp which i use (tikka xp) but i'm looking to have a regular flashlight as well when i don't want to look like a dork. I would be greatly appreciative of your suggestions and input. Here's my answers to the following questions:
online
2) Budget: An easy question, but you may change your mind after answering the rest!
Around $50
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
either:
_x__Every day carry small (2-4 inches).
_x__Every day carry medium (4-7 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
AA or 2xAA
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
_x__I want to navigate a dark room or read a map (0-10 lumens).
_x__I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
nice to have: ____Less than 1 yard/meter (reading, other close work)
_x__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_x__5-20 yards/meters (check out a noise in the backyard)
_x__30-50 yards/meters (check out a noise while camping)
nice to have: ____50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
I will be using this while backpacking and will need it to have a long runtime (12 hours+) on a low-ish setting. On higher output modes the battery life isn't as important as I'll have extra batteries handy.
____Not Important (A "night-stand" light).
_x__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
_x__I don't care.
_x__I don't know.
I want at least two light levels (high/low). More might be nice for battery usage optimization.
14)Material/Finish/Coating
__x__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
Thanks in advance!
online
Around $50
3) Format:
either:
6) Manufacturer:
AA or 2xAA
_x__I don't care.
_x__I don't know.
Thanks in advance!
