There are Mag HIDs in 10W, 14W etc. But I haven't seen a full power 35W HID Mag mod that still looks like a mag afterwards.
Here are some previous CPF references on similar projects:
Big Head method: Use a giant 4" head to house a slim ballast inside the head:
http://www.candlepowerforums.com/vb/showthread.php?223571-35W-HID-Maglite-Mod-Finished!-Beam-Shots
Big Neck Method: Download mag HID drop-in:
http://www.candlepowerforums.com/vb/showthread.php?241715-MagHID-Drop-in
Another one similar to download's method:
http://www.candlepowerforums.com/vb/showthread.php?174036-45w-HID-M-G
I had a round ballast laying around for a while, its too big to go into the mag tube until I realized that if I "think outside the tube"...
1. Cut the 3D mag tube above the switch
2. Grind the edge of the Mag tube to go inside the metal skirt of the round ballast,
Solder ballast to switch & inset into the mag body.
3. Sleeved for 3x18650 with recessed tail spring
4. Before JB weld the ballast to mag tube perminantly, connect a HID bulb for a quick test.
5. let there be light!
Sorry folks, I have run out of time...
