i say a small titanium light that takes rcr123/cr123.
has great style.4inchs or less.multi trit slots.comes with 2 heads,one with a neutral or warmer xm-l or xp-g designed for great flood,with 300+ lumens.and other head almost like a milkyspit creemator TIR thrower light,with a nice tint xr-e
(or if not 2 heads,the the ability to swap emitters and reflector to optic)
infinate ramping like a nitecore,0.1 lumen to max.
a piston drive light,but also with the ability to be a twisty.
a
b@rt 11mm tritium sphere inserted,and sunk into said titanium piston,with a nice flush norland,or perhaps supertough window to protect the sphere.
a deep pocket clip
highly efficent driver,that can be programed via the PD switch to run directdrive,or boost/buck so you can blaze away for 15 minutes at 500/600 lumens if you want.
awesome build quality,and top notch heat sinking and usability
can tailstand.high quality lanyard with hollow titanium ball at the end housing a
b@rt trit sphere,shining through artistic cutouts on ball. (if that is to much trit then replace the PD trit sphere with a triangle 3 trit slot,and just keep the lanyard trit sphere ball.)
