Hello All,
First let me apologize if this has already been written about, but in a quick search, I found nothing on this topic.
So, I just got a Maratac AAA Cu a couple of weeks ago, and I'm not going to lie, at first I was very displeased. Right out of the box (or paper bag in this case :shakehead), the light was failing to push through the modes. Sticking on medium, jumping to high, skipping low, and just showing all around erratic behavior when trying to switch between modes. This is to be expected over time for a light of this size at this cost, but when it arrives at your door? I find this unacceptable.
I read over everyone's suggestions on this issue, but nothing solved the issue. Then, completely on accident, I realized that if you tighten the head just about an either of a turn before it turns on, you can pull this little guy by the head into your palm and it will come on as if there's a momentary switch. When using the light in this manner, it switches between modes flawlessly! After this realization, this Cu has replaced my QTC Eiger as my EDC due to it's weight and size.
Hope this post helps some of you Maratac owners out there enjoy this little light in a new way.
Cheers.
Cheers.
