RedForest UK
- Joined
- Nov 28, 2009
- Messages
- 1,365
Light Name | Mode | Ceiling Bounce Lux | Estimated Lumens OTF |
LD20 Q5 | Low | 0.9 | 10.8 |
Med | 4 | 48 | |
High | 8 | 96 | |
Turbo | 14.3 | 171.6 | |
Fenix TK20 | Low | 4 | 48 |
High | 14.7 | 176.4 | |
Jetbeam BA20 | Low | 1.6 | 19.2 |
High | 20.6 | 247.2 | |
Eagletac T100C2w (Q3 5a) @3.9v | Low | 4.5 | 54 |
High | 13.9 | 166.8 | |
OEM Nitecore EZAA R2 | Low | 0.2 | 2.4 |
High | 7.8 | 93.6 | |
iTP A3 Std ed | High | 3.4 | 40.8 |
Nailbender 1amp XP-G R3 | Low | 1.2 | 14.4 |
Med | 7.7 | 92.4 | |
High | 23.5 | 282 | |
Custom 1amp XR-E Q4 | Low | 3 | 36 |
High | 17.1 | 205.2 | |
Custom 2.5amp XM-L T5 3C | Low | 2.8 | 33.6 |
Med | 16.5 | 198 | |
High (stable) | 51.7 | 620.4 | |
Ultrafire 3 mode drop-in IMR @4.2v | Low | 4 | 48 |
Med | 22.8 | 273.6 | |
High 1 sec | 80.1 | 961.2 | |
High stable | 66.5 | 798 | |
Ultrafire 3 mode eX-cell @4.1v | High 1 sec | 64 | 768 |
High stable | 62.5 | 750 | |
eX-cell @4.0v | 58 | 696 | |
Olight M3x U2 mod | Low | 5.4 | 64.8 |
High (stable) | 71.5 | 858 | |
Skyray 3x T6 '3800' heatsinked | Low | 12.1 | 145.2 |
Med | 73.5 | 882 | |
High 1 sec | 148.5 | 1782 | |
High (stable) | 142 | 1704 | |
Kaidomain U2 drop-in | High 1.4amp | 38 | 456 |
IMR 1.8amp | 45 | 540 | |
Nitecore EZCR2w RCR2 | Low | 1.3 | 15.6 |
High | 11 | 132 | |
Zebralight H501w | Low | 0.2 | 2.4 |
Med | 0.9 | 10.8 | |
High | 4.8 | 57.6 | |
Zebralight H51 | L1 | 0.2 | 2.4 |
M1 | 2.4 | 28.8 | |
H2 | 8.5 | 102 | |
H1 | 12.8 | 153.6 | |
Quark Mini AA R4 4B 14500 @4.15v | Low | 0.3 | 3.6 |
Med | 4.1 | 49.2 | |
High 1 sec | 22 | 264 | |
High (stable) | 20 | 240 | |
N30 30w HID | MAX | 231 | 2772 |
Romisen RC-2R4 R5 1.4amp mod | High | 27.4 | 328.8 |
Nitecore EX10 SP R2 RCR123 @4.15v | Low | 0.3 | 3.6 |
Med | 4.6 | 55.2 | |
High | 14 | 168 | |
DX Incan P60 module @4.1v | High | 7.2 | 86.4 |
Jetbeam BC40 | Low | 10.6 | 127.2 |
High | 79 | 948 | |
Klarus P2a | Low | 1.5 | 18 |
High | 20.5 | 246 | |
Fenix LD01 R4 | Med | 2.5 | 30 |
Low | 0.2 | 2.4 | |
High | 6.5 | 78 | |
Fenix E01 | High | 0.8 | 9.6 |
Nitecore D11.2 neutral R5 | Max | 12.3 | 147.6 |
Nitecore D10 90+ CRI +.2 circuit | Max | 7.6 | 91.2 |
Nitecore EX10 neutral R5 +.2 circuit | Max | 18.3 | 219.6 |
Olight S65 | Low | 1.7 | 20.4 |
Med | 17.7 | 212.4 | |
High:Start-Up | 62.8 | 753.6 | |
High:Regulated | 55.4 | 664.8 |
DRY Triple XM-L T6 | |||
Trustfire 2400 'Flames' 4.2v, 4.2A | Low | 11.9 | 142.8 |
Med | 58.1 | 697.2 | |
High | 137.8 | 1653.6 | |
Turbo 1 sec | 200 | 2400 | |
Turbo Stable | 173 | 2076 | |
Trustfire 2400 'Flames' 4.0v, 3.7A | Turbo 1 sec | 200 | 2400 |
Turbo Stable | 184 | 2208 | |
Xtar 2600 (sanyo 2600) 4.1v, 4.6A | Turbo 1 sec | 202 | 2424 |
Turbo Stable | 170 | 2040 |
I got a luxmeter today, so put together this list of lumen OTF reading for reference. All are done with the lense of each light and the lux-meter at the same height/position pointed at the same angle towards a white ceiling. Once I'd worked out the multiplier (12 exactly) based on my LD20 which has very accurately measured med/high modes I went through a number of my other lights for comparisons.
All P60 drop-ins are wrapped very tightly in copper tape and my custom ones, including the nailbender xp-g which I modded down from 1.4 to 1.0amp, are thermally potted also for best heat dissipation, ultra-clear lenses are also used on my P60 hosts.
Stable refers to the the output not having dropped more than .1 on the lux scale (1.2 lumens) in the last 3-4 seconds, and does not necessarily mean the light will stay flat at that output over a minute or more. In fact this is certainly not the case on some modules e.g. the ultrafire 3 mode as it runs unregulated, which is why I have included cell voltage prior to measurement for these lights.
I was particularly impressed with my TK20 (my first decent light) and my modded nailbender R3 neutral XP-G, both of which I had subjectively thought were overperforming for some time, it was nice to have that objectively confirmed.
