Noob Question about buckpuck
Alarus
I have a noob question about the use of buckpuck.
How do I hook up an AC/DC supply to the buckpuck after i attach a harnass to it ?
There are only two wires dangling out.
I am looking at hooking up a 21V, 3A output from an adaptor.
I know this is a very basic question but i really need help as to what equipements to procure.
evilc66
Which Buckpuck model are you looking at/using? There at a minimum should be four wires coming from the Buckpuck; two for incoming power, and two for LED connection. Depending on the model there may be two more wires for external dimming control. All of the connections are labled on the top of the Buckpuck, and are also diagramed in the datasheet available on the Luxdrive website.
mds82
Connecticut
on the buckpuck there is a red and black wire. the red wire is for the positive input which would connect to the + output of the PSU. the black wire would connect to the - output of the PSU. Make sure the PSU is off before everything is connected
