Hi Chris,
I use
this with any of my mid to large headed lights (Wildcat, HoundDog, M3X, Tiablo A10, SF M2, Cryos M2 bezel-based lights) and it has worked out great due to its large degree of adjustability. It can be belt-mounted vertically as well as horizontally. The durability of Maxpedition products is first rate!
One improvement I would personally like added is a heavy duty version of a 360 degree, rotating belt clip similar in function to the the Nite-Ize Lite Stretch Holster seen
here, but improve the clip design for improved speed of belt placement & removal (like my cell phone holster). I've trialed others at brick & morter stores and reviewed options online, and I personally haven't found a better option yet for the larger headed lights. Although
these are considerations from Brite-Strike.
Although the Nite-Ize holster
will work with any of my listed lights, it can be a pain to holster & remove lights that don't have a fairly plain body/battery tube. So it works perfectly for my Malkoff MD series lights. Unlike some reports that the rotating clip is not strong enough to hold its position with heavier lights, maybe I've been fortunate because I have several of these all have strong rotating mechanisms.
Also, I started trialing
this instead of using a lanyard to see if I like it. I hope this helps!
All the best,
John
