I figured my collection could use a P60 set up. I want a neutral 1 mode drop in that is bright as possible with out overdriving the LED too much. I was going to go with a 3.15A regulated 4000K XML neutral drop in by vinhnguyen54, is that a good choice? I plan on putting it in a 2011 Solarforce L2P and was going to try the stock switch and maybe purchase the McClicky kit to upgrade the switch. I also plan on getting the solarforce L2 S7 tailcap. My questions:
Does this sound like a good set up, would you make any changes?
Is that a good drive level for the XML? I want this thing to be as bright as possible for bursts of approximately 5 minutes or less, but I don't want to cook the LED either.
Is the McClicky kit necessary, will I notice a difference in the feel of the switch and/or the brightness? I read somewhere that the L2 S7 tailcap has a lot of resistance.
Will the McClicky kit install into the stock L2P solarforce switch or do I have to use a solarforce L2 S7 momentary/twist tactical switch?
EDIT: Seems that you can install the switch into a stock L2P, here is a post.
Thanks.
Sales Links Removed - Norm
Thanks.
