Chicken Drumstick
Really hoping someone can help me here. I recently dug out my NiCd powered MagLite MagCharger. After a couple of house moves it had got packed away and forgotten for a few years. But I want to revitalise it and maybe even LED upgrade it.
But I've got an issue with it, it seems to have a lose connection somewhere. When you rotate the head the light will turn off and on and quite often become quite dim. If you shake the light, twiddle the head or apply downward pressure on it, it will some times sort its self, sometimes not.
I've stripped it down bar removing the switch and reassembled, but can't see anything obvious causing it.
My hope is, someone here will have a bright idea on what might be causing it, or what I should investigate next.
Thanks.
Thanks.
