IMR 14500 in a D10?
nbjly
I got a couple IMR 14500's the other day, and charged them up and put one in a Nitecore D10 that is in a Ti shell. The LE was modded with a neutral XR-E
It worked fine, I smelled that BAD smell and turned it off. I took the head off, the smell was worse.
It didn't work at first, now it seems ok, except the now the head must be loosened for it to behave as it did before with the head tight. With the head tight it acts like the momentary as it did before with the head loosened, except it won't turn off. It sat for about a week, and I was going to show someone it's odd behavior and of course it worked as it should. Then I loosened the head and it went back to it's bizzarro ways.
Nitecore says "and other batteries of the same size" does that include IMR's ?
