The Fenix-Store
Page 1 of 2 12 LastLast
Results 1 to 30 of 42
Thread: XTAR S1 (3*XM-L U2, 2800lm)
    Arrow XTAR S1 (3*XM-L U2, 2800lm)
    XTAR S1
    LED: 3x Cree XM-L U2
    Battery: 3x18650/18700 Li-ion
    Working Voltage: 2.75-4.2V
    Output/Runtime: min. 30lm (330h), max. 2800lm (95m)
    Max range: 360m
    Max Intensity: 32500cd
    Switch: Head magnetic ring switch
    Mode: SOS/Strobe/High/Preset/Select
    Water resistance: IPX-8 standard
    Material: 6061 Aluminium, HA Type-III
    Impact resistant: 1m
    Size: 83mm (head), 47mm (body), 240mm (length)
    Weight: 888g (excluding batteries)
    pics
    + new XTAR 18650 3100mAh (Panasonic NCR18650A cell inside) coming soon
    Flashaholic* Glenn7's Avatar
    Jul 2006
    Tasmania, Australia (the butt end of oz)
    Default Re: XTAR S1 (3*XM-L U2, 2750lm)
    Interesting...
    It would be great if it would really have 2750 lumen's we'll see, 83mm head looks promising for some throw - but good find gopajti!!!
    Jun 2010
    South Korea
    Looks like cannon!
    I've heard it's a follow-up model for D30, D31 released in 2009.
    Thanks for good information. gopajti!
    *Flashaholic* kj2's Avatar
    The Netherlands
    Looks good , but only Max range: 359m and Max Intensity: 32300cd, IMO a little bit low for this kind of light.
    Mostly reading.
    Jun 2010
    South Korea
    When looking at the figures, it's not bad compared to TM11 & RRT-3 .
    - S1..............TM11.........RRT-3
    - 32,300 cd....20,000cd....30,000cd
    - 359m..........283m..........346m
    The Netherlands
    Well, in that case, those are nice numbers
    -only the working voltage isn't good. "Working Voltage: 2.7-4.2V" - 3* 18650 3,7V = 11,1V.
    Mostly reading.
    Flashaholic* ico's Avatar
    Aug 2011
    Philippines
    I guess they're connected in parallel
    May 2007
    Santa Rosa, Ca
    I guess the cat's out of the bag now. I do like the preset & select system they use.
    It sure is a humongous torche
    Flashaholic* bigchelis's Avatar
    Oct 2008
    Morgan Hill, CA
    I parralel if I understand correctly, that means you add up the mA capacity. So, it would be 4.2V input and about 6000~8000mAh capacity depending on the cells.
    While that may seem great, at potentially 9A hitting each cell......well lets say the OTF lumens could and in my experience do suffer due to cell sag.
    IMHO it would have been better off like the Dry XM-L which is 12.4V input and only 3A~5A per cell. Same power just less cell sag.
    bigC
    Surefire 6P with Malkoff M60 simple, bright, efficient.
    Quote Originally Posted by bigchelis View Post
    bigC
    ummmm, I'm no expert, but I don't think so
    if each cell were dumping 9A, that'd be 27A at 4.2V. There wouldn't be any sag because it would go poof...
    http://batteryuniversity.com/learn/a...configurations
    Apr 2006
    SINGAPORE, South East Asia
    Actually, it is about ~3.7V input for the driver after sag and current is around 9 amps. Each cell sees 1/3 of that, 3A. Like the TM11 but that one has 1 additional cell. Those 3 cells would act as if it is one big cell with 8+ AH battery.
    bigC
    Series or parallel, driving 3 LEDs at 3A each pulls 3 amps from each battery regardless.
    Looks like a control ring interface?
    "Switch: Head magnetic ring switch"
    first post updated
    Jul 2006
    Woooooooh its massive!!
    Default Re: XTAR S1 (3*XM-L U2, 2800lm)
    Quote Originally Posted by gopajti View Post
    Now that's a flashlight!
    May 2007
    Santa Rosa, Ca
    Where do you get these pictures gopatji?!
    Jake
    S1 pics originally posted: shoudian forum. (battery pictures are mine)
    The Netherlands
    new batteries yes!
    Mostly reading.
    Jun 2010
    South Korea
    So good!
    Apr 2006
    From the beam profile, it seems like it would be more than than 30k cd, with the light driven so hard and with U2. I have a good number of DRYs and a DRY drivered SR3800. They already very nearly touch 30k cd. This light has reflector size between the DRY and various budgetlight 3 x XM-Ls and the TK70.
    Mar 2011
    USA
    Quote Originally Posted by 2100 View Post
    According to gopajti's number obtained from shoudian.com, it is more than 30k cd (32,300 cd). Would be great to see it compared to a TK70.
    Nikon D700 [14-24mm F2.8] F5.6, 1/8s, ISO2000, WB 5500K
    RRT3 XM-L
    XTAR S1
    RRT3 XM-L
    XTAR S1
    pics from shoudian
    Wow look at those beam shots, the RRT3 has a lot better spill compared to the XTAR, I don't really like the beam on the XTAR.
    Mar 2011
    USA
    the S1 definitely has throw capabilities. Wide and deep reflectors. What do you guys reckon? According to the data, they should have similar throw.
    Very nice cool white beam though, unlike the green of the Jetbeam.
    The Netherlands
    nice throw, but the shape of the spill of the S1- I dont like.
    Mostly reading.
    I saw in the last time a lot of flashlights with 3 Leds and 3 or 4 18650-batteries. These flashlights are big and unwieldy. I think, it ´s on time to make a better battery than Lithium-18650. The chemistry of this new battery must be better than now, so that one battery reach 6000 - 10.000 mAh and 5 -7 A in size like the 18650. If I see the XTAR S1, then I see a floodlight, but not a flashlight.
    Unenlightened
    Aug 2011
    Here's a couple of pics I took in my yard with the S1, they're not the greatest but it was cold out!
