Fallingwater
I've always liked cheap lights to tinker with and modify to fit my needs (my main EDC is a first-gen L-Mini whose body is the only thing left original), but lately the willpower to spend hours fixing my creations has been lacking. I'm getting tired of stripping the light with alarming regularity to fix the switch, or resolder the springs, or clean the hell out of it to minimize power losses, or what have you.
So I'm looking at a proper, high-quality EDC that'll work about as well as my current one, but without all the quality issues.
While browsing random product pages online I came across the Nitecore IFE2, which on the surface seems exactly what I want in a light: high-quality build (I own a Defender Infinity and I always liked its build quality, I assume later Nitecore products kept it up), high-power at 345 lumens, rotary dial so I don't have to bother with modes, and a forward clicky so I can use it as a focus assist light with my camera without it changing modes all the time. It's really expensive for my standards, but quality doesn't come cheap, and just this once I can take the expense.
There's only one problem, and that problem is the EagleTac T20C2 with the XML head. The interface is not as good, build quality seems a bit less impressive and it's less pocketable (might have to grind off that anti-roll ring). But: 720 lumens! It's really easy to forgive defects in a light when it puts out twice as much light as the alternative. The fact that it's noticeably cheaper helps too.
Edit: scratch that - the alternative is now the Zebralight SC600. The T20C2 is not quite pocketable enough.
What do you think? And are there any alternatives I've missed? Note that I can't possibly afford the really high-end lights - anything above $120 or so is a no-go.
